OS_CE › Forums › Octopus › User exchange › 3/4 time? possible?
- This topic has 16 replies, 3 voices, and was last updated 17 years, 8 months ago by
gseher.
AuthorPosts
July 15, 2008 at 19:15 #807
Mike
ParticipantIs there some track timing that will equate to 3/4 time? Where 12 steps would equal 16 steps of a track in normal time…
I guess the multiplier would be something like 1.333? I can’t wrap my head around it. 1/3 multiplier obviously is too slow, but it is the closest thing.
cheers
ripeJuly 16, 2008 at 00:18 #1689gseher
KeymasterUm – i’m not sure what you mean? 3/4 is just changing the step length to 12… i think you mean triplets? in which case you need to use the 1.5 multiplier or 1/1.5
July 16, 2008 at 02:22 #1690Mike
ParticipantYeah I’m not sure what I mean either
The futureretro revolution has 3/4 time signature, which makes it play 12 steps in the span of one measure.
from the revolution manual:
"SELECTING A TIME SIGNATURE
There are two time signatures to choose from when writing a pattern, which are 3/4 and 4/4.
Each time signature simply divides the measure of a pattern into 12 (3/4) or 16 (4/4) equal parts. "I want to duplicate this on the octopus, but also have tracks that play 16 steps in the same period of time. It doesn’t seem possible.
cheers
ripeJuly 16, 2008 at 19:51 #1691gseher
Keymastertrust me, i’ve thought about this long and hard man. i think 98% of most octopus users are doing boring ass 4/4 stuff. i’m so bored of it myself.
what you want is 3/4.. 1/4t, 1/8t, 1/16t
and 1/32t timing.i don’t think it’s possible.
if one was able to get that resolution in say logic audio or an asr-10, and then save as smf dump, can one import that back into the pus via midi? talking with another user he brought up an excellent point. where is your target file going to end up and how will it snap to what your end result should be?
maybe i’m making a monster oversite here… have i missed something?
July 16, 2008 at 19:59 #1692Mike
ParticipantI tried recording the output directly from the Revo (running in 3/4) to the Octopus, but it doesn’t turn out right. I don’t think the STA offset can be set high or low enough to keep the timing.
Yes, .75 timing would work on my 16 step tracks to keep them in sync with a 12 step track running at normal speed. hmm. Most of my stuff is "boring" old 4/4 stuff anyways
but I’d like to experiment.Oh, and my "target" is always the octopus, I construct the entire track using the page clustering.
cheers
ripeJuly 16, 2008 at 20:12 #1694gseher
Keymasterripe,
is there a way one can "snap to grid" everything together to do like a global quantized feel for the entire pattern set?
*don’t break my balls if this has already been discussed, it’s just a quick question.
thanks bro
July 16, 2008 at 21:33 #1695Mike
ParticipantI believe you can do this by selecting all tracks and reducing the STA factor to zero.
cheers
ripeJuly 17, 2008 at 05:21 #1697Adam Wilson
Participantripe wrote:
Quote:I believe you can do this by selecting all tracks and reducing the STA factor to zero.And clearing the STA map of each track is the more destructive approach.
July 17, 2008 at 08:34 #1699gseher
KeymasterIndeed – the quickest way to quantize everything to the grid is double click SEL and hold it, turn down the STA encoder for about 8 clicks – done.
And back to the original question about 3/4 time – dividing a measure into 12 parts of equal length:
1. Make a chain of 3 tracks and make them 3x speed each. So now, a measure is the time it takes to play all 3 (the full chain).
2. The 12 interesting steps are now the steps 1, 5, 9, 13 in each of the track respectively.
Hope this is what you were looking for.
GabrielPost edited by: gseher, at: 2008/07/17 10:41
July 18, 2008 at 15:50 #1693gseher
Keymasterphase linear wrote:
Quote:trust me, i’ve thought about this long and hard man. i think 98% of most octopus users are doing boring ass 4/4 stuff. i’m so bored of it myself.what you want is 3/4.. 1/4t, 1/8t, 1/16t
that is possible – you need to use the 1.5,3 1/1.5, 1/3 etc tempo multipliers
July 21, 2008 at 21:11 #1696gseher
KeymasterIn my book, 12 over 16 means triplets. check the 1.5 multiplier. (dunno if in future future-retro it means something else) 16*1.5 = 12.
I must have been the only one that cried for months over the "broken" 1.5 multiplier.
Cheers,
/RJuly 21, 2008 at 23:31 #1706Mike
Participant16 * 1.5 = 24
16 * .75 = 12! Which is why I asked for a .75 multiplier which would allow the use of a 12 step track in 16 steps of time, and then your note triggers are at useful times.
cheers
ripePost edited by: ripe, at: 2008/07/22 01:32
Post edited by: ripe, at: 2008/07/22 01:35
Post edited by: ripe, at: 2008/07/22 05:47
July 22, 2008 at 03:16 #1707gseher
Keymasterbut isn’t the point that you don’t use all 16 steps?… 16 steps make no sense in triplet time. make the track length 12 steps and then use 1.5 or 1/1.5
Post edited by: machina, at: 2008/07/22 05:16
July 22, 2008 at 03:43 #1710Mike
ParticipantIf you make the track 12 steps and play it at 1.5 multiplier it will play 18 steps while another track that is 16 steps and has multiplier of 1 plays once. So it would take three loops of the 12 step track to equal two loops of the 16 step track… not quite what we (I) wanted.
I was trying to get a 12 step track to play in the same amount of time as a 16 step track at multiplier of 1. This would require a multiplier of .75 on the 12 step track, or if the 12 step track was at multiplier 1, then the other 16 step tracks would need to be at 1.33 times speed.
cheers
ripeJuly 22, 2008 at 10:08 #1711gseher
KeymasterQuote:I was trying to get a 12 step track to play in the same amount of time as a 16 step track at multiplier of 1. This would require a multiplier of .75 on the 12 step trackWe need this!
AuthorPosts
- You must be logged in to reply to this topic.
