- This topic has 6 replies, 3 voices, and was last updated 17 years, 9 months ago by
George Stobbelaar.
January 1, 2009 at 13:23 #913
George Stobbelaar
ParticipantHi and Happy New Year,
I am experimenting with step events. When I create a step event for position it switches sometimes automatically to velocity (sometimes after first run sometimes after a few cycles). Probably I am missing something but WHAT?
Please helpPS
It’s a bit confusing that there is a genoqs.com where I am a registered user; but on genoqs.net which seems the same site I am not registered??Post edited by: admin, at: 2009/03/14 04:37
Post edited by: admin, at: 2009/03/14 04:44
January 14, 2009 at 14:04 #2191George Stobbelaar
ParticipantI stil don’t understand why this happens. Can someone please help me!!??
lebenspuls wrote:
Please helpPost edited by: lebenspuls, at: 2009/01/14 16:13
January 14, 2009 at 16:23 #2222Jordi
ParticipantIt’s never happened to me, so I don’t know where to begin.
January 15, 2009 at 06:34 #2223gseher
KeymasterI have been puzzled about it too, but now I think I have an idea.. maybe.
When you zoom into a step to set the event, technically speaking you are looking at a step "position" filled with some step data, which corresponds to the step of course.
When the position event is active and the sequencer is running, the step data gets updated to the data of the step that moves into the position you are looking at. So that may be the cause of the trouble. In earlier OS versions the view would not follow the data but stick to the physical position.
That makes it seem like the step data is changing by itself, but what you are actually seeing is the step data set being swapped altogether.
What OS version are you on? With that info I can track for sure if this is the cause of the problem or not.
Cheers,Gabriel
January 15, 2009 at 18:53 #2224George Stobbelaar
ParticipantHi,
thanks for the answer. OS is 1.6
Best wishesPieter
January 27, 2009 at 05:38 #2225George Stobbelaar
ParticipantI really would like to know wether it is a bug and I have to wait for an update, or if I should install the OS new…
I would like to use step events on position!!!
gseher wrote:
Quote:That makes it seem like the step data is changing by itself, but what you are actually seeing is the step data set being swapped altogether.
Cheers,Gabriel
Post edited by: lebenspuls, at: 2009/01/27 06:39
Post edited by: lebenspuls, at: 2009/01/27 06:57
February 8, 2009 at 14:38 #2238George Stobbelaar
ParticipantToday I had time to reinstall OS 1.6 again. Now it works as it should
