OS_CE › Forums › Nemo › User exchange › Assigning tracks for drum machine
- This topic has 6 replies, 2 voices, and was last updated 15 years, 5 months ago by
Josh.
September 5, 2010 at 11:15 #1099
Josh
ParticipantOk, possibly a stupid question but basically im stuck!! I have figured out the guts of nearly everything on this brilliant sequencer but for the life of me i can’t figure this out which i assumed would be trivial.
So if anybody can help me or indeed use the nemo to sequence a vermona drm 1 mk3, how did you do it.No problem assigning the first 4 tracks to say the kick drum, snare, hihat, hihat 2 but when i try and assign another one say the clap – it is doubling up on the track of say the kick drum – if you get me!!!!
Basically I need to assign 8 individual tracks – anybody know how to do this – do i set up two pages? The manual is not very good at explaining this kind of stuff
Any help much appreciated
thanks
JoshPost edited by: empirix, at: 2010/09/05 13:53
September 5, 2010 at 22:15 #2926Carlos Dalla-Fiore
Participantyou use the 2nd horizontal row.
you can play any combination of the 4 rows simultaneously.
I dont understand how your managing to get the kick and clap playing together unless your using chords.
I have a "touched by sound DRM-1" which is basically the MK1 of the machine your using.
September 5, 2010 at 22:37 #2927Josh
Participantthanx, still no joy, what mode – page? so i hold page and then would select any of the buttons in the 2nd row, so say the first button that doubles up as pit? do i create a cluster? any steps appreciated,cheers
Post edited by: empirix, at: 2010/09/06 00:58
September 6, 2010 at 22:01 #2928Carlos Dalla-Fiore
Participantgrid mode.
there you have 4 rows of 16 pages.
the top row contains 1 or more pages sequencing drm instruments 1-4
the second row 1 or more pages for instruments 5-8.September 6, 2010 at 23:14 #2929Josh
Participantok which is what im doing: which causes doubling up.
steps: grid mode selected(blinking orange led) =>i select the first page on row 1(double click) now in page mode => setup instruments 1 -4 no problem all is wellback in grid mode => double click(now in page mode) on 1st led 2nd row => setup instruments 5 – 8 => first initial step is recognised on first sequence iteration for each instrument, 2nd sequence iteration -> instruments double up, so for example the kick and snare double up as the kick is led 1 on page1 and snare is led 1 on page 2, do you see my problem => what am i doing wrong.
thanx for your help
Post edited by: empirix, at: 2010/09/07 01:16
September 7, 2010 at 23:48 #2930Carlos Dalla-Fiore
Participanti dont follow from here.
empirix wrote:
Quote:…first initial step is recognised on first sequence iteration for each instrument, 2nd sequence iteration -> instruments double up, so for example the kick and snare double up as the kick is led 1 on page1 and snare is led 1 on page 2, do you see my problem => what am i doing wrong.thanx for your help<br /><br />Post edited by: empirix, at: 2010/09/07 01:16
your setting up whole the tracks in the page on the second row to different midi notes right?
for example:
row 1, page 1:
track 1 = C-1
track 2 = D-1
track 3 = E-1
track 4 = F-1row 2, page 1:
track 1 = G-1
track 2 = A-1
track 3 = B-1
track 4 = C-2your setting up the whole track right? Not just the first step in each track. I usually start by triggering all steps in a track then holding the track selector button to the left of the rows in page mode and turning PIT till i arrive at the desired instrument, which machine-guns. Then copy this track down and offset to the next instrument.
September 9, 2010 at 12:06 #2932Josh
Participantno i wasn’t – quite obvious,working like a dream, now to master the effector and all will be well, i owe you beers
thanx a lot
