OS_CE › Forums › Octopus › New features › crazy config idea
- This topic has 2 replies, 3 voices, and was last updated 16 years, 7 months ago by
matt hillier.
December 10, 2009 at 06:22 #1046
rachel polanskis
ParticipantHi,
using the USB to update the OS gave me a crazy idea.
Would it be possible to upload information into the Octopus as a file:1) to contain personal and private information, address, contact, serial number etc
to allow the Octopus to identified if it is lost or stolen2) A text file to turn on and off features in the Octopus eg
A config file to enable certain functions to allow the Octopus to perform a certain way:blink_rate = how fast the cursor blinks
command_set = eg remapping certain buttons to different features
compatibility_mode = settings to use certain "modular" functions perhaps
obsoleted by a previous OS release that a user likes and wants to maintainSo for example then you would edit your text config file, upload it via USB
and then it would set certain defaults, features and settings personal to the user.For example it could be useful to have a beta version of the code that can be
enabled with a config setting – the user enables it by editing/upload the config
or disables the feature they do not want to use.Or premapped CC’s could be defined in the file, overriding any defaults.
Or whatever parameter could be exposed from the API, read from the file and set….
If the code is modular enough, this could be used to make Octopus kind of "pluggable" so that you select what modules you want (eg some mad hyperstep
templates) and then the Octopus loads them in via the config and default settings.More memory intensive processes the user does not use could be disabled or
armed to be as deadly as you want.Users could share config settings or maps by file to be supported via a common
standard eg name:value pairs and module lists.I do not know how hard this would be to implement but it sort of seems a logical’
jump in how we could use/configure/personalise the Octopus and given how modular
it seems the code is already.rachel
December 20, 2009 at 11:37 #2678paul
ParticipantGreat Idea Rachel !
hopefully Gabriel will be back soon to commentJanuary 12, 2010 at 11:38 #2685matt hillier
Participantnice ideas !
paul wrote:
Quote:Great Idea Rachel !
hopefully Gabriel will be back soon to comment -
