- This topic has 16 replies, 7 voices, and was last updated 17 years, 2 months ago by
Adam Wilson.
August 3, 2009 at 11:26 #1002
Gabriel Seher
ParticipantDear all,
the Nemo OS v1.62 is now available in the download area. Let me know what you think.
Cheers, GabrielAugust 3, 2009 at 13:25 #2491Adam Wilson
ParticipantExcellent, thanks for letting us know.
Is there some info somewhere of the updates/fixes?Cheers
EDIT: I see it now in the releases section… Hypersteps!!! Sounds exciting
Post edited by: elemental, at: 2009/08/03 15:35
August 3, 2009 at 16:19 #2492Andrew Capon
ParticipantHi Guys,
I have not been able to find any info of how to upload this update to the NEMO.
Anyone know how?
Thanks
Andy
August 3, 2009 at 16:21 #2493Andrew Capon
ParticipantGabriel just emailed me, power on while pressing ESC.
August 4, 2009 at 00:36 #2494John Audette
ParticipantDo I simply use a Sysex editor and send it over or does Nemo need to be set to a certain mode to accept the data?
August 4, 2009 at 01:49 #2495John Audette
ParticipantFor all those having trouble finding upgrade procedures, here you go:
UPLOAD INSTRUCTIONS
How to upload the OS file onto your machine
Probably the first improvement that you will notice with the new OS
os that the OS file for version 1.60 does not require any intermediary
steps, as veteran users may know it from the past.
The OS file may be sent directly to the machine and received there
accordingly by the incumbent OS. Note however that it wi! not recognize
your stored sequence data!!! Now follow these steps:
1. Boot your machine in System mode. Boot the machine while
you hold the ESC key pressed. You should see the System screen,
which is characterized by all LEDs in the MODE block (inside the
circle) being lit orange. The number displayed in the numeric field
of the circle denotes your existing OS version. For example, a 140
will denote the OS version 1.40.
2. Send the OS file to the machine. Use your favorite SYS-EX
handling device or software to play the SYS-EX file provided. As
soon as transmission starts you should see how the machine interface
gets cleared and behaves like a progress bar indicator.
3. Acknowledge successful transmission of the OS file. Once
transmission is complete, make sure you are seeing a clear display,
with only a red blinking Program LED. This indicates that transmission
was successful. If you are seeing an orange blinking Program
LED it means that something went wrong and you need to
retransmit. Most of the times it helps if you reduce the transmission
speed on the sender’s end.
4.Write the new OS file to flash. If you see the red blinking Program
LED, you may press the Program button and wait for the machine
to write the new OS file to flash. The process is usually indicated
by another progress bar. Make sure to let the machine complete
this operation, or you may render it inoperable! (That is not
the same as non-recoverable however, just in case you were worried
that you may have to part with your baby for a while..)
5. Boot without loading your data from memory. OS version
1.60 does not understand machine state data generated by previous
versions of the OS (however, we expect further OS versions to understand
data generated by OS version 1.60 and later). In order to
not fill the memory with non-understandable data, you have to
boot the machine with the CLR button (3rd from top in the MUT
column) pressed. Now you have a clean machine, and you should
write this clean state to memory by pressing GRID + Program.
From here you may resume normal operation of the machine.
Congratulations! You have successfully updated your instrument to
what we consider the best operating system there ever was.August 4, 2009 at 17:51 #2496Roderick van Erp
ParticipantTx for the new Firmware Gabriel….works perfectly and loaded without a hitch.
August 6, 2009 at 11:07 #2497Jordi
Participantdouble post
Post edited by: audible, at: 2009/08/06 13:09
August 6, 2009 at 11:08 #2498Jordi
ParticipantI’ve followed the upload instructions step by step and still can’t get my Nemo to work in 1.62.
When the sysex file transmission is complete and the ‘progress bar’ display is all full of leds, then it clears, but I can’t see the blinking red ‘Program’ led. It remains blinking green as if it was waiting for more messages.
I’ve tried using the MidiOx and SendSX apps with different delay times, from 0 to 500 ms. I’ve tried different USB ports (I’m using an EMU Midi1x1 as the interface). They all seem to send the sysex file in full but I can’t figure out what is going wrong afterwards.
Any clues?
Post edited by: audible, at: 2009/08/06 13:10
August 6, 2009 at 11:08 #2499Jordi
August 6, 2009 at 11:39 #2507Gabriel Seher
ParticipantDo you have the possibility to try another MIDI interface?
August 6, 2009 at 11:45 #2508Jordi
Participantgseher wrote:
Quote:Do you have the possibility to try another MIDI interface?Not by now.
August 6, 2009 at 11:51 #2510Gabriel Seher
ParticipantCan you take a look at the USB route? it is slightly more technical but it is a very safe bet. The document is at the bottom of the software download page. Write me an email if you have any questions.
GabrielAugust 6, 2009 at 23:47 #2512Jordi
ParticipantI’ve tried another usb-midi interface and it hasn’t worked either.
If I venture into the usb port upload procedure I’ll let you know the results.
Post edited by: audible, at: 2009/08/07 01:48
August 7, 2009 at 01:46 #2527Luca Leoni
ParticipantThanks for the new firmware Gabriel. I’m very happy with the new grid-track behaviour!
